![]() | Home > General & Technical (L663) > L663 D300 Auxiliary drive belt squeal. |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1125 ![]() ![]() |
I’ve had this before at about 17k miles,and warranty fixed it. However at 33k it’s started squealing again.
When cold the belt is making a regular chirp, it goes silent once warmed up. Has anyone got a picture of the installation, or a diagram of components. I think it’s one of the idler pulleys. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3019 ![]() ![]() |
That's interesting.
How do you know which starting method a Defender is using. ls there any way to tell? |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 320 ![]() ![]() |
If it’s starts in hybrid mode it’s a muffled sound, whereas if it’s an earlier d300 and the mod was done you will hear the starter engage and then the diesel engine sound.
My first D300 was August 21 and the mod done circa 1 year later. I now have a Jan 23 d300 which starts a bit more hybrid like…but I’m not 100pc sure as it’s presently marooned in Group 1 Chester with suspension knocking and am presently running around in an Ewok hybrid which definitely starts in hybrid mode and reserves 3 - 5pc of electric to do so. |
Yes I do remember this. It involved a software update as well as new belt and gubbins.
I’m hoping it’s just the idler this time. There is an awful lot of vibration of the belt driven components when it’s running. I’m not actually sure which bit is the tensioner. As you look down the front of the engine under the coolant hose, on the right hand side there is what looks like an alternator. The pulley on that seems to be mounted to a bracket that vibrates a lot when the engine is running. Access and visibility is poor, so was hoping to get a diagram of parts. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
My D250 was delivered in November 2022 so hopefully the modification was done. l've never had any issues with vibration or belts squeaking.
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
Had mine done twice now
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Two years and 36,000 miles and not a steak. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
