Home > Td5 > Defender Td5 clutch noise
texpis
2007 Defender 90 Puma 2.4 CSW Java Black
Hi all I’ve searched the forum to see if this is a common issue I’ve had the car 2001 Td5 station wagon. I’ve owned it for for 7 years and it’s always had a noise when feathering the clutch in reverse it’s a loud noise not unlike a horn is getting worse but still mainly in reverse the odd bit in forward. I’ve always thought it was the release bearing but looking through the internet it could be other components. I’m at the point where I would like to rectify it even if it means a clutch change. I would rather not change the clutch just to find it’s something else
Post #1051118 8th Nov 2024 9:57pm
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
Does is happen more often in when it's cold / first thing in the morning?
Mine did that too until I replaced the clutch. It's either the release bearing or the spigot bush.
Post #1051120 8th Nov 2024 10:38pm
texpis
It does it all the time in reverse I think that’s because the clutch is feathered in reverse fullin and full out its fine
Mick
Post #1051121 8th Nov 2024 11:06pm
revd
Mine groans when cold as did my previous Td5 - which was still on original clutch when I sold it with almost 200k - so I personally wouldn't swap out a clutch just because it is a little bit grumpy first thing in the morning
Post #1051154 9th Nov 2024 2:36pm
texpis
Thanks for the reply. It’s not first thing it’s every time I use reverse but you’re right I may leave it a while
Mick
Post #1051164 9th Nov 2024 4:17pm
4RF RDS
FWIW, my 99 110 CSW has been groaning with clutch peddle depression on cold start for 110,000 Kms. When it is in the sun and warm outside no noise on cold start. It goes away after full warm up. I suspect its the release bearing but, as the saying goes… if it ain't broke … 🤷‍♂️
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1051245 10th Nov 2024 3:37pm
MadTom
Look for spigot bush - small bush inside of rear end of crankshaft supporting input shaft of gearbox. Mine was screaching for few years, and it was slowly going worse and worse, up the tha state of bad gear change, and with car in first low, it was moving even pressed clutch pedal. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1051264 10th Nov 2024 7:05pm
