Home > Td5 > Defender Td5 clutch noise |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 66 |
Does is happen more often in when it's cold / first thing in the morning?
Mine did that too until I replaced the clutch. It's either the release bearing or the spigot bush. |
8th Nov 2024 10:38pm |
texpis Member Since: 13 Jun 2009 Location: Stockton-on-tees Posts: 52 |
It does it all the time in reverse I think that’s because the clutch is feathered in reverse fullin and full out its fine
Mick |
8th Nov 2024 11:06pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 160 |
Mine groans when cold as did my previous Td5 - which was still on original clutch when I sold it with almost 200k - so I personally wouldn't swap out a clutch just because it is a little bit grumpy first thing in the morning
9th Nov 2024 2:36pm |
Thanks for the reply. It’s not first thing it’s every time I use reverse but you’re right I may leave it a while
Mick |
9th Nov 2024 4:17pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 954 |
FWIW, my 99 110 CSW has been groaning with clutch peddle depression on cold start for 110,000 Kms. When it is in the sun and warm outside no noise on cold start. It goes away after full warm up. I suspect its the release bearing but, as the saying goes… if it ain't broke … 🤷♂️
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
10th Nov 2024 3:37pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 636 |
Look for spigot bush - small bush inside of rear end of crankshaft supporting input shaft of gearbox. Mine was screaching for few years, and it was slowly going worse and worse, up the tha state of bad gear change, and with car in first low, it was moving even pressed clutch pedal. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
10th Nov 2024 7:05pm |
