![]() | Home > General & Technical (L663) > Expedition Rack and Rear Roof Aerial |
H1Tad Member Since: 20 Jul 2024 Location: Maine Posts: 147 ![]() ![]() |
The answer is... "it depends". What is the tent made out of? If its fiberglass/ABS plastic then GPS signals penetrate those materials. However *most* RTT's use at least an aluminum (sometimes honeycomb) floor so yes, it will impact the GPS signal. You should still be able to *get* signal but it may take longer to acquire. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
o-ren-ishii Member Since: 25 Jul 2023 Location: The Hague Posts: 41 ![]() ![]() |
I got the whole roof completely full from front to back with no space to spare and the signal never has been a problem.
Neither gps nor phone. Usually the car has better reception than the phones in the car. ![]() Click image to enlarge |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1434 ![]() ![]() ![]() |
I have the Autohome roof tent on mine which covers the aerial and I can confirm there aren't any problems
![]() ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 60 ![]() ![]() |
A little bit off-topic but where did you source a 75th coloured side pod, and what do those cables coming down from you roof rack do? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1258 ![]() ![]() |
The wires are Bush Cables, been around for years. They are to push branches away from the windscreen.
"Are bush cables legal in the UK? The police do not advise you to have bushcables fitted when using the highway. However are they 'illegal' ? the answer is no, they are not illegal. Our premium Stainless Steel bushcables are fully removable, we also stock quick 'tie backs' and 'quick release carbines' to relocate or remove your bushcable sets. |
other Grassmere Green Carriers are available ..... https://www.ebay.co.uk/itm/395072556145?_s...R46Rt6HcZA & https://www.ebay.co.uk/itm/387529750401?_s...R5iSzqHcZA |
Haha sharp eye! I got it painted in the same colour , grashmere green. The guy did want to do a double take and came back with a device to measure the paint. Came out pretty good ![]() The wires are bush wires. It’s quite handy if you are going off-road through dense areas with branches sticking out into the road. Even with these things the car - that was brand new- is a bit scratched all round haha. Battle scars :p |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
I have roof top tent, jerry cans and water container up there on an Eezi Awn roof rack and never had a problem.
(for some reason I can not upload pictures so cant show you) "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
