Home > General & Technical (L663) > Expedition Rack and Rear Roof Aerial
TheEscapist
Hello all
Putting roof rails and expedition rack on my 110.
The rack has a cut out at the rear which is I assume to allow the rear roof aerial to still work well.
I’m putting a roof tent on top of the rack though which will cover the whole rack surface so will this interfere with gps from the aerial?
Most hard top roof tents seme to be around 2.1m long which is the entire length so hard to avoid. Even the official Land Rover tents by Autohome are so I assume no issues…
Thanks in advance!
Paul
Post #1050267 30th Oct 2024 2:02pm
H1Tad
United States
The answer is... "it depends". What is the tent made out of? If its fiberglass/ABS plastic then GPS signals penetrate those materials. However *most* RTT's use at least an aluminum (sometimes honeycomb) floor so yes, it will impact the GPS signal. You should still be able to *get* signal but it may take longer to acquire. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
2003 Hummer H1 P400 Firehouse Red
2008 Toyota FJ Cruiser
Post #1050269 30th Oct 2024 2:50pm
o-ren-ishii
Netherlands
I got the whole roof completely full from front to back with no space to spare and the signal never has been a problem.
Neither gps nor phone. Usually the car has better reception than the phones in the car.
Post #1050275 30th Oct 2024 4:08pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I have the Autohome roof tent on mine which covers the aerial and I can confirm there aren't any problems Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1050311 31st Oct 2024 12:52am
A1C6
Australia
A little bit off-topic but where did you source a 75th coloured side pod, and what do those cables coming down from you roof rack do?
Post #1050324 31st Oct 2024 10:22am
LR Nuts
The wires are Bush Cables, been around for years. They are to push branches away from the windscreen.
"Are bush cables legal in the UK?
The police do not advise you to have bushcables fitted when using the highway. However are they 'illegal' ? the answer is no, they are not illegal. Our premium Stainless Steel bushcables are fully removable, we also stock quick 'tie backs' and 'quick release carbines' to relocate or remove your bushcable sets.
Post #1050325 31st Oct 2024 10:32am
LR Nuts
other Grassmere Green Carriers are available .....
https://www.ebay.co.uk/itm/395072556145?_s...R46Rt6HcZA
https://www.ebay.co.uk/itm/387529750401?_s...R5iSzqHcZA
Post #1050330 31st Oct 2024 11:24am
o-ren-ishii
Netherlands
Haha sharp eye! I got it painted in the same colour , grashmere green. The guy did want to do a double take and came back with a device to measure the paint.
Came out pretty good Smile
The wires are bush wires. It’s quite handy if you are going off-road through dense areas with branches sticking out into the road. Even with these things the car - that was brand new- is a bit scratched all round haha. Battle scars :p
Post #1050331 31st Oct 2024 11:34am
BruceT
South Africa
I have roof top tent, jerry cans and water container up there on an Eezi Awn roof rack and never had a problem.
(for some reason I can not upload pictures so cant show you) "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #1052841 25th Nov 2024 7:03am
