Home > Maintenance & Modifications > Caster Angle
jmbdef
Caster Angle
Hi everyone,
I have a couple of questions about caster angle.
Details of build are : 1997 110 300tdi. Tough Dog 2 inch lift suspension. 500kg constant in rear (made for 130). Weight is around 2700kg with overlanding accessories. Rear perhaps slightly more than 2 inch lift, but I think it is close. (I took stock measurements wrong so hard to compare back exactly).
I have 0-300kg springs on the rear first but the rear sat lower so I swapped to the 500kg.
After the switch my steering was very vague. I went to an alignment shop and found caster angle to be -1.6°. So on recommendation of suspension shop and mechanic and I went with 3° caster correcting arms from Terrafirma.
This helped the steering and caster is at +0.3°.
Symptoms now are vague feeling steering at higher speeds, brakes pull randomly either way.
I have had brakes checked, and swivel preload.
My mechanic thinks it may still be caster angle.
Could the caster angle be the culprit?
Would the higher Rear have an affect on caster angle? Once I am more loaded once the overlanding setup is complete, or on a trip will it be brought more +?
What else can I check?
What should the caster angle be?
How much should the 3° arms have changed the caster angle? Am I correct in thinking they should have changed it by 3°, which by the shop measurements they didn't.
If caster angle is still the problem, will fitting 6° arms be better for me?
Thank you
Jean
Post #1046077 18th Sep 2024 10:25am
TexasRover
How is the 2" lift achieved. Is the caster corrected back to stock?
Vague steering can also be play in various joints. Are you sure every part is 100%?
Post #1046111 18th Sep 2024 4:02pm
jmbdef
Lift is Tough Dog springs. I am pretty sure caster is not back to stock.
Other parts have been checked
Post #1046158 19th Sep 2024 6:51am
TexasRover
Ok I see you have fitted caster corrected radius arms. You would have to measure what the caster is now.
There are a bunch of things that would affect the steering including weight distribution. Not sure where this additional weight is. Do you have anti-roll bars fitted?
Post #1046161 19th Sep 2024 7:24am
Mo Murphy
Are you using a standard length panhard rod ?
50 Shades of Pennine Grey
Post #1046168 19th Sep 2024 8:46am
jmbdef
Additional weight is a roof tent, 2 spare wheels, fridge, drawer, awning etc.
Yes caster is 0.3° now. With 3° arms. Maybe I should fit 6° arms instead?
No anti-roll bars, although I would like to fit I think
Post #1046169 19th Sep 2024 8:47am
jmbdef
Yes, standard length panhard rod.
Post #1046183 19th Sep 2024 11:21am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
as per LR specification, caster angle should be at 3° 15' ± 45', but I'm sure you've figured that out already.
Instead of changing again your radius arms, you also have the option to fit caster corrected swivel housings, I know Bripart makes some giving an additional 3°.
/Mat
Post #1046991 27th Sep 2024 5:04pm
jmbdef
Thank you very much, yes my current swivels are getting a bit worn, so that may be an option...
Post #1047040 27th Sep 2024 11:33pm
Mining Subsidence Stu
United Kingdom 1991 Defender 90 200 Tdi HT Caledonian Blue
Does the steering self-centre? If no, then it's castor angle. My westfield is neutral and you've got to steer it 100% of the time yourself, rather than letting the castor do it some of the time.
Post #1055776 28th Dec 2024 4:51pm
