Home > Maintenance & Modifications > Caster Angle |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1042 |
How is the 2" lift achieved. Is the caster corrected back to stock?
Vague steering can also be play in various joints. Are you sure every part is 100%? |
18th Sep 2024 3:02pm |
jmbdef Member Since: 08 Dec 2021 Location: London Posts: 5 |
Lift is Tough Dog springs. I am pretty sure caster is not back to stock.
Other parts have been checked |
19th Sep 2024 5:51am |
Ok I see you have fitted caster corrected radius arms. You would have to measure what the caster is now.
There are a bunch of things that would affect the steering including weight distribution. Not sure where this additional weight is. Do you have anti-roll bars fitted? |
19th Sep 2024 6:24am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
Are you using a standard length panhard rod ?
19th Sep 2024 7:46am |
Additional weight is a roof tent, 2 spare wheels, fridge, drawer, awning etc.
Yes caster is 0.3° now. With 3° arms. Maybe I should fit 6° arms instead? No anti-roll bars, although I would like to fit I think |
19th Sep 2024 7:47am |
Yes, standard length panhard rod.
19th Sep 2024 10:21am |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 184 |
as per LR specification, caster angle should be at 3° 15' ± 45', but I'm sure you've figured that out already.
Instead of changing again your radius arms, you also have the option to fit caster corrected swivel housings, I know Bripart makes some giving an additional 3°. /Mat |
27th Sep 2024 4:04pm |
Thank you very much, yes my current swivels are getting a bit worn, so that may be an option...
27th Sep 2024 10:33pm |
