![]() | Home > Maintenance & Modifications > Caster Angle |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1212 ![]() ![]() ![]() |
How is the 2" lift achieved. Is the caster corrected back to stock?
Vague steering can also be play in various joints. Are you sure every part is 100%? |
jmbdef Member Since: 08 Dec 2021 Location: London Posts: 5 ![]() ![]() |
Lift is Tough Dog springs. I am pretty sure caster is not back to stock.
Other parts have been checked |
Ok I see you have fitted caster corrected radius arms. You would have to measure what the caster is now.
There are a bunch of things that would affect the steering including weight distribution. Not sure where this additional weight is. Do you have anti-roll bars fitted? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2315 ![]() ![]() ![]() |
Are you using a standard length panhard rod ?
Additional weight is a roof tent, 2 spare wheels, fridge, drawer, awning etc.
Yes caster is 0.3° now. With 3° arms. Maybe I should fit 6° arms instead? No anti-roll bars, although I would like to fit I think |
Yes, standard length panhard rod.
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 196 ![]() ![]() ![]() |
as per LR specification, caster angle should be at 3° 15' ± 45', but I'm sure you've figured that out already.
Instead of changing again your radius arms, you also have the option to fit caster corrected swivel housings, I know Bripart makes some giving an additional 3°. /Mat |
Thank you very much, yes my current swivels are getting a bit worn, so that may be an option...
Mining Subsidence Stu Member Since: 06 Mar 2024 Location: Cornwall Posts: 32 ![]() ![]() ![]() |
Does the steering self-centre? If no, then it's castor angle. My westfield is neutral and you've got to steer it 100% of the time yourself, rather than letting the castor do it some of the time.
