Home > Technical > Loss of coolant and power loss |
Neil1957- Member Since: 09 Sep 2024 Location: Ayamonte Posts: 1 |
Brand new to the lady scene. A steep learning curve ahead I fear. Hopefully someone can shed some light on this.
Recently purchased defender. All good for 4 weeks. Then after about 30km sudden loss of power. Stopped . 10 mins later all fine for a short period then again. Checked coolant level. Low. Topped it up about 2 litres. All good for a we days then same again. Have checked fluid levels topped up. Left engine running and started to search for a leak. No leak found. Found out that the electronics have been altered to give a 25hp increase. Have also read about a cylinder head sensor that shuts engine down when hot. Also possible head gasket. Does all of this sound correct? Where is the best place to start? TIA |
9th Sep 2024 2:57pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 864 |
Which model/engine do you have? 2008 2.4 110 Utility Station Wagon XS.
9th Sep 2024 3:27pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 490 |
If you have steam from exhaust check the EGR and cooler for internal leaks first, oh and be careful with your nails!
10th Sep 2024 11:10am |
