Home > Technical > Loss of coolant and power loss
Neil1957-
Spain 2007 Defender 110 200 Tdi HT Select Colour
Brand new to the lady scene. A steep learning curve ahead I fear. Hopefully someone can shed some light on this.
Recently purchased defender. All good for 4 weeks. Then after about 30km sudden loss of power. Stopped . 10 mins later all fine for a short period then again. Checked coolant level. Low. Topped it up about 2 litres. All good for a we days then same again. Have checked fluid levels topped up. Left engine running and started to search for a leak. No leak found. Found out that the electronics have been altered to give a 25hp increase.
Have also read about a cylinder head sensor that shuts engine down when hot. Also possible head gasket.
Does all of this sound correct? Where is the best place to start?
TIA
Post #1045311 9th Sep 2024 3:57pm
BrickBox
Which model/engine do you have? 2008 2.4 110 Utility Station Wagon XS.
Post #1045316 9th Sep 2024 4:27pm
Re: Loss of coolant and power loss
Neil1957- wrote:
Brand new to the lady scene. A steep learning curve ahead I fear. ...
Seldom has a truer word.been spoken, mind you I suspect that this forum is not the best place for advice about ladies!
Post #1045329 9th Sep 2024 6:34pm
Linds Hanson
If you have steam from exhaust check the EGR and cooler for internal leaks first, oh and be careful with your nails!
Post #1045407 10th Sep 2024 12:10pm
