Home > Td5 > Rear axle half-shafts (Td5 110 CSW 2005)
tony.g
Hi all,
Recently bought a pair of h/duty shafts, with the loose drive flanges, circlips and bolts.
The new flanges are thicker and stick out more than the original ones, the result being that the circlip grove will be about 20mm further out than the original grove was. The new shafts are the exact length as the originals.
I'm concerned that this pulls the shaft about 20mm further out from the corresponding splines in the diff. Is this going to be a problem?
Thanks for any advice.
Post #1039252 6th Jul 2024 7:01am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Have you got the right drive flanges as the early ones where thicker and the later Tdi onwards are thinner 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1039253 6th Jul 2024 7:25am
BrickBox
I’d be going single piece and be done with all the 2 piece issues, personally. 2008 2.4 110 Utility Station Wagon XS.
Post #1039255 6th Jul 2024 8:19am
tony.g
Thanks for that - I did specifically tell them it was a 2005 Td5 so def. not a pre Tdi, so I've written back asking them to send the correct ones.
Post #1039259 6th Jul 2024 8:44am
tony.g
I did toy with the idea of a pair of those, but I've now already spent £300 + on the shafts and flanges so am stuck with them now.
We live and learn.
Thanks anyway for the response.
Post #1039260 6th Jul 2024 8:47am
Dinnu
AFAIK the earlier thicker flanges will not fit anyway as the diameter is slightly smaller/bigger depending which way you look at. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1039264 6th Jul 2024 9:35am
MK
I suggest you remove the oil seal inside the stud (or is it in the axle assembly?) so you run the drive flange and halfshaft in the "wet mode". These will increase the longevity of the new parts.
We live and learn.
Thanks anyway for the response.[/quote] Puma 110" SW
Post #1039273 6th Jul 2024 12:34pm
