Home > Td5 > Rear axle half-shafts (Td5 110 CSW 2005) |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 137 |
Have you got the right drive flanges as the early ones where thicker and the later Tdi onwards are thinner 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
6th Jul 2024 7:25am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 731 |
I’d be going single piece and be done with all the 2 piece issues, personally. 2008 2.4 110 Utility Station Wagon XS.
6th Jul 2024 8:19am |
tony.g Member Since: 25 Aug 2017 Location: uk Posts: 21 |
Thanks for that - I did specifically tell them it was a 2005 Td5 so def. not a pre Tdi, so I've written back asking them to send the correct ones. |
6th Jul 2024 8:44am |
I did toy with the idea of a pair of those, but I've now already spent £300 + on the shafts and flanges so am stuck with them now. We live and learn. Thanks anyway for the response. |
6th Jul 2024 8:47am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3330 |
AFAIK the earlier thicker flanges will not fit anyway as the diameter is slightly smaller/bigger depending which way you look at. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
6th Jul 2024 9:35am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2386 |
I suggest you remove the oil seal inside the stud (or is it in the axle assembly?) so you run the drive flange and halfshaft in the "wet mode". These will increase the longevity of the new parts.
I did toy with the idea of a pair of those, but I've now already spent £300 + on the shafts and flanges so am stuck with them now. We live and learn. Thanks anyway for the response.[/quote] Puma 110" SW ............................................................. Earth first. Other planets later |
6th Jul 2024 12:34pm |
