Home > Puma (Tdci) > Help needed, stuck in Mongolia as a solo overlander |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2400 |
I cannot see what is in pic #2, but by the shape looks like the gasket from the oil return from the turbocharger.
Try to find a Ford dealer and ask for P/N 1331076. However, from the workshop manual it does not look like metallic. Puma 110" SW ............................................................. Earth first. Other planets later |
1st Jul 2024 12:22pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 995 |
It must be nice to make a trip al the way from China to Europe with so little mechanical experience.. I would be worried sick about everything, mostly as it turns out about nothing.
1st Jul 2024 12:33pm |
Breakingcycles Member Since: 12 Apr 2024 Location: Hong kong Posts: 3 |
Thanks MK, precisly that, the metal plate for the oil out from the turbo! Much appreciated for the info, will check the ford parts 🙏🙏🙏 |
1st Jul 2024 12:44pm |
Indeed, I have zero mechanica knowledge , did a crash course from a friend on changing oil, that’s about it. But it ain’t stopping me it definitely out of my comfort zone 1000% |
1st Jul 2024 12:47pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1913 |
it is indeed the turbo oil return line, it looks to be in decent condition, i would use some gasket sealer with it and for peace of mind replace the gasket when convenient.
There are lots of suppliers out there that could help, Foundry 4X4, Turner engineering, Maltings, LRparts, Rimmer brothers, island 4x4 etc. Foundry would be my first choice they are extreamly helpful. 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
1st Jul 2024 5:37pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3381 |
I would cut a new gasket from compressed non asbestos gasket. These are resistant to 450dC, and should last long enough. Just a sharp knive and some commonly available gasket material all that is needed.
As I understand that is the oil drain connection on the turbo. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
1st Jul 2024 6:10pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5607 |
Leaking a little bit of oil, or a lot of oil. A little weep wouldn’t bother me whilst touring. Just something to keep an eye on. It’s the drain, not the supply.
1st Jul 2024 8:05pm |
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 182 |
2nd Jul 2024 5:05pm |
Tjhappel Member Since: 08 Aug 2012 Location: Southern California Posts: 32 |
Nice work man!! So jealous…. Hope the trip is good and yeah land rovers…. You’ll get there
17th Jul 2024 5:44am |
