![]() | Home > General & Technical (L663) > Adding ladder before roof rack |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 993 ![]() ![]() |
It all depends on what roof rack you are fitting. Some of the low profile racks may not allow for the ladder.
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 128 ![]() ![]() |
![]() Click image to enlarge I used the LR Expedition rack and Molle plates (Powerful uk) then you can mount ladder on either side of the vehicle. |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 141 ![]() ![]() |
LR's fitting instructions:
https://accessories-instructions.landrover.com/enUSA/new-defender Hope that helps. ![]() Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
SparklesMcgraw Member Since: 04 Sep 2023 Location: WA Posts: 13 ![]() ![]() |
Thanks. Was just wondering if mechanically it would have to be removed before fitting a rack. It’s just a matter of timing as I’m having other things also fitted at LR but just haven’t decided on a rack yet. I’m guessing if I go simple roof bars these can be added with the ladder already in place?
Yes, I've got the ladder fitted permanently and my roof cross bars can go on and off as required. That's on the 110, on the 90 there appear to be 2 versions of the cross bars & as I understand it one set can't be removed once the ladder is in place. Current vehicle: 2020 Defender 110S
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 41 ![]() ![]() |
I installed my factory rack before the ladder, which was a mistake. I needed to remove the back corner roof rack bracket and then loosen the rest of the rack in order to get the ladder hardware mounted.
So order of operation for a factory roof rack should be: 1. Lunch box/ Ladder 2. Factory rack For roof bars it doesn't matter the order of operation. |
Excellent feedback thank you!
