Home > General & Technical (L663) > Adding ladder before roof rack |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1056 |
It all depends on what roof rack you are fitting. Some of the low profile racks may not allow for the ladder.
29th Jun 2024 3:52pm |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 135 |
29th Jun 2024 6:19pm |
Click image to enlarge I used the LR Expedition rack and Molle plates (Powerful uk) then you can mount ladder on either side of the vehicle. |
29th Jun 2024 7:58pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 148 |
LR's fitting instructions:
https://accessories-instructions.landrover.com/enUSA/new-defender Hope that helps. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
29th Jun 2024 9:59pm |
SparklesMcgraw Member Since: 04 Sep 2023 Location: WA Posts: 13 |
Thanks. Was just wondering if mechanically it would have to be removed before fitting a rack. It’s just a matter of timing as I’m having other things also fitted at LR but just haven’t decided on a rack yet. I’m guessing if I go simple roof bars these can be added with the ladder already in place?
29th Jun 2024 11:42pm |
Yes, I've got the ladder fitted permanently and my roof cross bars can go on and off as required. That's on the 110, on the 90 there appear to be 2 versions of the cross bars & as I understand it one set can't be removed once the ladder is in place. Current vehicle: 2020 Defender 110S
30th Jun 2024 10:01pm |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 41 |
I installed my factory rack before the ladder, which was a mistake. I needed to remove the back corner roof rack bracket and then loosen the rest of the rack in order to get the ladder hardware mounted.
So order of operation for a factory roof rack should be: 1. Lunch box/ Ladder 2. Factory rack For roof bars it doesn't matter the order of operation. |
1st Jul 2024 12:29am |
Excellent feedback thank you!
1st Jul 2024 12:56am |
