Home > General & Technical (L663) > Adding ladder before roof rack
SparklesMcgraw
Australia
I’m planning on adding some accessories to my new defender with the deployable ladder being one. I haven’t yet decided on what rack to go for so would adding the ladder first mean it would have to be removed to then add a roof rack? Still deciding on either platform or bars.
Thanks
Post #1038711 29th Jun 2024 1:54pm
LR Nuts
It all depends on what roof rack you are fitting. Some of the low profile racks may not allow for the ladder.
Post #1038713 29th Jun 2024 2:52pm
stevemfr
France
If you're going to be going for the OEM expedition rack, it needs to be at least partially removed to mount the ladder.
But just out of curiosity: what are you going to be doing on your roof without a rack? Why the ladder?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1038722 29th Jun 2024 5:19pm
LR Nuts
I used the LR Expedition rack and Molle plates (Powerful uk) then you can mount ladder on either side of the vehicle.
Post #1038730 29th Jun 2024 6:58pm
WizzardPrang
LR's fitting instructions:
https://accessories-instructions.landrover.com/enUSA/new-defender
Hope that helps. Thumbs Up Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1038744 29th Jun 2024 8:59pm
SparklesMcgraw
Australia
Thanks. Was just wondering if mechanically it would have to be removed before fitting a rack. It’s just a matter of timing as I’m having other things also fitted at LR but just haven’t decided on a rack yet. I’m guessing if I go simple roof bars these can be added with the ladder already in place?
Post #1038746 29th Jun 2024 10:42pm
WizzardPrang
Yes, I've got the ladder fitted permanently and my roof cross bars can go on and off as required. That's on the 110, on the 90 there appear to be 2 versions of the cross bars & as I understand it one set can't be removed once the ladder is in place. Current vehicle: 2020 Defender 110S
Insta: wizzardprang
Post #1038810 30th Jun 2024 9:01pm
chpsk8
United States
I installed my factory rack before the ladder, which was a mistake. I needed to remove the back corner roof rack bracket and then loosen the rest of the rack in order to get the ladder hardware mounted.
So order of operation for a factory roof rack should be:
1. Lunch box/ Ladder
2. Factory rack
For roof bars it doesn't matter the order of operation.
Post #1038823 30th Jun 2024 11:29pm
SparklesMcgraw
Australia
Excellent feedback thank you!
Post #1038825 30th Jun 2024 11:56pm
