![]() | Home > Puma (Tdci) > VCV Replacement Photos |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 628 ![]() ![]() |
Not sure myself.. Just what came to mind when I read the comment about the colouring.. I have done some basic heat treating of high carbon steels and am frequently Re hardening and tempering various punches in the workshop, so I do know the colouring can be more or less polished off👍
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
The blueing is on the part of it that hasn't been ground. 2007 110 TDCi Station Wagon XS
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
Only if the CHT has failed, little happens other than running richer on fuel than it should and using more fuel than it should.
ugh.[/quote] So, does it happen even the CHT is sending the right temperature? ![]() ............................................................. Earth first. Other planets later |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 850 ![]() ![]() ![]() |
I’m just about to try to remove my SCV. The grey pipe with a he brass nut, what does it fit on to? There was a small conical spring inside when I undone it. Does the small end of the spring point towards the nut?
All done. New SCV fitted which while being a bit fiddly was easy enough.
Engine sounds slightly different (could just be my imagination?) but drives nice and smooth. I had a few instances of no power for a second when pulling away from stationary so hopefully the new valve will cure this. Jim |
The one that comes out of the back of vac pump? There was no spring apparent in mine. 2007 110 TDCi Station Wagon XS |
