Home > Puma (Tdci) > VCV Replacement Photos
Page 2 of 2 <12
That was what I was wondering as I don’t remember the new ones to have the blueing.
But that being said, it’s a vague memory so I’m 50/50 on that. TheThunder Rolls🇬🇧🇺🇸
Post #1038569 27th Jun 2024 3:05pm
andy63
Not sure myself.. Just what came to mind when I read the comment about the colouring.. I have done some basic heat treating of high carbon steels and am frequently Re hardening and tempering various punches in the workshop, so I do know the colouring can be more or less polished off👍
Post #1038571 27th Jun 2024 3:30pm
Bluest
The blueing is on the part of it that hasn't been ground. 2007 110 TDCi Station Wagon XS
Post #1038573 27th Jun 2024 3:40pm
andy63
Post #1038575 27th Jun 2024 3:55pm
MK
Only if the CHT has failed, little happens other than running richer on fuel than it should and using more fuel than it should.
ugh.[/quote]
So, does it happen even the CHT is sending the right temperature? Question Puma 110" SW
Post #1038577 27th Jun 2024 4:36pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
I’m just about to try to remove my SCV. The grey pipe with a he brass nut, what does it fit on to? There was a small conical spring inside when I undone it. Does the small end of the spring point towards the nut?
Post #1038707 29th Jun 2024 11:54am
jim4244
All done. New SCV fitted which while being a bit fiddly was easy enough.
Engine sounds slightly different (could just be my imagination?) but drives nice and smooth. I had a few instances of no power for a second when pulling away from stationary so hopefully the new valve will cure this.
Jim
Post #1038717 29th Jun 2024 4:14pm
Bluest
The one that comes out of the back of vac pump? There was no spring apparent in mine. 2007 110 TDCi Station Wagon XS
Post #1038798 30th Jun 2024 5:11pm
Page 2 of 2 <12
