![]() | Home > General & Technical (L663) > Gap 4 help on terrain response Auto |
DC-Defender Member Since: 23 May 2024 Location: USA Posts: 10 ![]() ![]() |
I'm interested as well if anyone knows! I found within the IID GAP Announcement post configs that enable it in addition to multiple other items but not specifically what enables Auto by itself.
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 111 ![]() ![]() |
Auto Terrain Response did NOT work on mine after I activated it until about two days later. Then it was like it was never an issue. Pivi resets and letting the car sleep didn't help, but it started working after time.
JonathanP Member Since: 01 Jun 2024 Location: Barnard Castle Posts: 24 ![]() ![]() ![]() |
Put a battery charger on you car and fully charge it up for at least 12+ hours, and with it fully charged leave it charging overnight. In the morning I switched my car on and left it for a while until it powered itself off. I switched it on again and started the engine this time and it was there!
Super3imi Member Since: 14 Jun 2024 Location: Kuwait Posts: 14 ![]() ![]() |
Pjeski can yoy share the setting you configured? 22MY Defender 110 XS , Carpathian grey
It worked!!!!
![]() As he said when you configure the setting WAIT for two days for the Auto option to appear it suddenly pops up . Just use yoyr car normally until it pops up These are the settings i have used MultiCAN-476 ATPC Was HDC only Is HDC and LSPC MultiCAN-696 ATCM Auto TR Mode Switch Was Auto Terrain Response Mode selection switch not fitted Is Auto Terrain Response Mode selection switch fitted MultiCAN-736 Config TR Fitment Was Not Configured Is Off Road Configuration MultiCAN-754 Auto TR Prog Mode Was Not fitted Is Fitted MultiCAN-755 Config TR Mode Was Not available for selection Is Available for selection with timeout MultiCAN-778 ATPC Select In FCPB Was Control interface not available in FCPB Is Available as shared purpose button MultiCAN-778 Ter Auto Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-789 Drive Mode Order Was All Terain Vehicle Standard Order Is AlI Terrain Vehicle Including Auto Order MultiCAN-797 Ter CT Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-798 Ter CP Select In FCPB Was Control interface not available in FCPB Is Rotary used for selection within touch screen MultiCAN-853 ATPC Button Type Was Not fitted Is Hard Button Fitted For this last configuration for 853 i used Is Hard Button fitted While others Changed from Was Not fitted Is Not Supported I guess waiting two days does the trick and Not supported or Hard Button doesn’t change a thing So please Wait !! For two days to see if it works . 22MY Defender 110 XS , Carpathian grey |
Can you provide an update on how it went?
Lonfred Member Since: 20 Sep 2024 Location: Barcelona Posts: 6 ![]() ![]() |
Are you able to manually switch to AUTO mode? When I tried this AUTO appeared on the touchscreen but I was not able to switch to AUTO.
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 112 ![]() ![]() |
To activate Auto Terrain Response, you hold down the Terrain Response button on the center console until it tells you that Auto mode has been selected on the instrument cluster. Alternatively, you can press the same button once and activate it using the dial or the screen. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
