Home > General & Technical (L663) > Gap 4 help on terrain response Auto
Super3imi
Kuwait
Has anyone activated Terrain response 2 Auto? On GAP 4
I activated the configurable terrain but no luck with the Auto option
I have a 2022 Defender xs 110
Post #1037434 14th Jun 2024 12:15pm
DC-Defender
United States
I'm interested as well if anyone knows! I found within the IID GAP Announcement post configs that enable it in addition to multiple other items but not specifically what enables Auto by itself.
Post #1038519 27th Jun 2024 12:03am
pjeski
United States
Auto Terrain Response did NOT work on mine after I activated it until about two days later. Then it was like it was never an issue. Pivi resets and letting the car sleep didn't help, but it started working after time.
Post #1038580 27th Jun 2024 5:11pm
JonathanP
United Kingdom 1998 Defender 90 300 Tdi SW Caledonian Blue
Put a battery charger on you car and fully charge it up for at least 12+ hours, and with it fully charged leave it charging overnight. In the morning I switched my car on and left it for a while until it powered itself off. I switched it on again and started the engine this time and it was there!
Post #1038681 28th Jun 2024 10:39pm
Super3imi
Kuwait
Pjeski can yoy share the setting you configured? 22MY Defender 110 XS , Carpathian grey
Post #1038799 30th Jun 2024 5:32pm
Super3imi
Kuwait
It worked!!!! Very Happy Big thanks to ( pjeski )
As he said when you configure the setting WAIT for two days for the
Auto option to appear it suddenly pops up . Just use yoyr car normally until it pops up
These are the settings i have used
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
MultiCAN-696 ATCM Auto TR Mode Switch
Was Auto Terrain Response Mode selection switch not fitted
Is Auto Terrain Response Mode selection switch fitted
MultiCAN-736 Config TR Fitment
Was Not Configured
Is Off Road Configuration
MultiCAN-754 Auto TR Prog Mode
Was Not fitted
Is Fitted
MultiCAN-755 Config TR Mode
Was Not available for selection
Is Available for selection with timeout
MultiCAN-778 ATPC Select In FCPB
Was Control interface not available in FCPB
Is Available as shared purpose button
MultiCAN-778 Ter Auto Select In FCPB
Is Rotary used for selection within touch screen
MultiCAN-789 Drive Mode Order
Was All Terain Vehicle Standard Order
Is AlI Terrain Vehicle Including Auto Order
MultiCAN-797 Ter CT Select In FCPB
MultiCAN-798 Ter CP Select In FCPB
MultiCAN-853 ATPC Button Type
Was Not fitted
Is Hard Button Fitted
For this last configuration for 853 i used
Is Hard Button fitted
While others
Changed from
Was Not fitted
Is Not Supported
I guess waiting two days does the trick and Not supported or Hard Button doesn’t change a thing
So please Wait !! For two days to see if it works . 22MY Defender 110 XS , Carpathian grey
Post #1038914 1st Jul 2024 8:46pm
DC-Defender
United States
Can you provide an update on how it went?
Post #1049600 23rd Oct 2024 11:42pm
Lonfred
Spain
Are you able to manually switch to AUTO mode? When I tried this AUTO appeared on the touchscreen but I was not able to switch to AUTO.
Post #1051476 12th Nov 2024 7:50pm
CincyRovers1
United States
To activate Auto Terrain Response, you hold down the Terrain Response button on the center console until it tells you that Auto mode has been selected on the instrument cluster. Alternatively, you can press the same button once and activate it using the dial or the screen. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1051491 12th Nov 2024 8:22pm
