![]() | Home > Technical > Pumps per brake line |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 519 ![]() ![]() ![]() |
Personally I’d just put most of a litre bottle through if it’s not been done before or you don’t know when it’s been done. I usually almost empty the reservoir on each wheel about three times then go round again if there’s much left. Your not supposed to keep it as it attracts water moisture.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
I would open bleed nipples and let it all drain out..better still suck it all out, then add new. Cheers
