Home > Technical > Pumps per brake line
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Flushing new brake through the pipes one corner at a time, how many pumps of the pedal will ensure new is coming through. I know the colour will change if the fluid is due but not knowing if the current fluid is recent or not I want to make sure new is all the way through. Also considering the different lengths of pipe to each corner. Thanks
Post #1037227 12th Jun 2024 3:43pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Personally I’d just put most of a litre bottle through if it’s not been done before or you don’t know when it’s been done. I usually almost empty the reservoir on each wheel about three times then go round again if there’s much left. Your not supposed to keep it as it attracts water moisture.
Post #1037230 12th Jun 2024 4:04pm
jst
I would open bleed nipples and let it all drain out..better still suck it all out, then add new. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1037252 12th Jun 2024 8:22pm
