Home > Technical > Pumps per brake line |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 431 |
Personally I’d just put most of a litre bottle through if it’s not been done before or you don’t know when it’s been done. I usually almost empty the reservoir on each wheel about three times then go round again if there’s much left. Your not supposed to keep it as it attracts water moisture.
12th Jun 2024 5:04pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7939 |
I would open bleed nipples and let it all drain out..better still suck it all out, then add new. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Jun 2024 9:22pm |
