Home > Modifications & Maintenance (L663) > L663 OBD Scanner Potential Issues
91dm
Ireland
Hello,
I'm not sure if this has been covered before.
Has anyone seen a battery warning message display because of the OBD reader they have been using?
Someone told me using the wrong scanner can cause this and require a software update to fix?
Interesting to hear from anyone that has had an issue.
Thanks
Post #1036655 6th Jun 2024 11:20am
lightning
l've had a "low battery" warning when using the GAP tool, apparently the voltage had dropped under 12v
But nothing happened apart from the fact that it then wouldn't do any changes.
Post #1036852 8th Jun 2024 3:20pm
91dm
Ireland
I've done quite a lot of looking on Google and can't find any mention of it.
Unless the guy was using a cheap bluetooth OBD reader which caused issues.
Post #1037245 12th Jun 2024 8:17pm
Huwrhys
My car scanner OBD reader is fine left plugged in until I connect to it whilst the car is dormant. Then it drains the battery within a few hours. If I don’t connect to it until the engine is running it seems fine. 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1037289 13th Jun 2024 11:11am
lightning
l don't think you are supposed to leave it plugged in to the vehicle
Post #1037312 13th Jun 2024 2:43pm
Huwrhys
Does state on the box that you can do that, but I haven’t since it flattened my battery! 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1037315 13th Jun 2024 3:00pm
taffy
Post #1044654 3rd Sep 2024 2:11pm
taffy
Hi Just joined so still trying out how to communicate but what is an OBD reader?
Post #1044656 3rd Sep 2024 2:13pm
Huwrhys
It’s the socket down by your knee that’s used for diagnostics. On Board Diagnostics. A plug in unit connects to your phone by Bluetooth and gives all kinds of diagnostic information. 24MY D300 130 X-Dynamic HSE Santorini Black
Post #1044657 3rd Sep 2024 2:15pm
