Home > Modifications & Maintenance (L663) > L663 OBD Scanner Potential Issues |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2909 |
l've had a "low battery" warning when using the GAP tool, apparently the voltage had dropped under 12v
But nothing happened apart from the fact that it then wouldn't do any changes. |
8th Jun 2024 2:20pm |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 33 |
I've done quite a lot of looking on Google and can't find any mention of it.
Unless the guy was using a cheap bluetooth OBD reader which caused issues. |
12th Jun 2024 7:17pm |
Huwrhys Member Since: 27 Mar 2024 Location: Hornchurch Posts: 134 |
My car scanner OBD reader is fine left plugged in until I connect to it whilst the car is dormant. Then it drains the battery within a few hours. If I don’t connect to it until the engine is running it seems fine. 24MY D300 130 X-Dynamic HSE Santorini Black
13th Jun 2024 10:11am |
l don't think you are supposed to leave it plugged in to the vehicle
13th Jun 2024 1:43pm |
Does state on the box that you can do that, but I haven’t since it flattened my battery! 24MY D300 130 X-Dynamic HSE Santorini Black
13th Jun 2024 2:00pm |
taffy Member Since: 03 Sep 2024 Location: London Posts: 15 |
3rd Sep 2024 1:11pm |
Hi Just joined so still trying out how to communicate but what is an OBD reader?
3rd Sep 2024 1:13pm |
It’s the socket down by your knee that’s used for diagnostics. On Board Diagnostics. A plug in unit connects to your phone by Bluetooth and gives all kinds of diagnostic information. 24MY D300 130 X-Dynamic HSE Santorini Black
3rd Sep 2024 1:15pm |
