![]() | Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Seapod, the 265x65R18 have the same rolling diameter so no problem running them. The wheel offset will effect the amount of splatter up the sides. I'm running spacers for a better turning circle giving it a wider stance but have also fitted Glynn Lewis mudflap extensions which do an excellent job of keeping the sides clean. A lot of other people use Dirt-D-Fenders, which help with the splatter. I have a set for the rear but m yet to fit them.
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Seapod Member Since: 15 Sep 2016 Location: Devon Posts: 46 ![]() ![]() ![]() |
Thanks James - I have been checking out your Defender after you posted above. Very nice indeed - you have already done many of the things I plan to do.
Are you still running the original wheels ie 235/85/16 ? I see you have spacers added, hence the extended mud flaps, but wasn't quite clear on the tyres themselves. |
Thank you Seapod, yes running standard 235x85r16 on boosts et33 with 30mm spacers. Hope to change wheels soon but think I'll stick with 16" but probably 265x75r16... James
pesto_trader Member Since: 26 Jun 2013 Location: Oslo Posts: 148 ![]() ![]() ![]() |
18" Anthracite Sawtooths on 265/65 Bfgs:)
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Yannis - looks great and I believe they're Startech wheels, but would be useful for everyone to add what wheels and tyres they are and what sizes
Correct they are from JE engineering. Tyres are Atturo R800 285/60R18.
Here is a comparison to the factory setup. The on road grip is unreal, they also reduce roll in the corners a lot due to a smaller side wall. No difference in conform over bumps etc. Terrible in snow. Yet to test on mud. ![]() Click image to enlarge |
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
Very very nice rims Yannis
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Mach 5 16x9 with 285/75/16 BFG MT KM2
Before and after ![]() Click image to enlarge ![]() Click image to enlarge and a few other photos ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
Hank, are you sure they're 16x9?
fairly sure, why do you ask? I have a spare 8" Mach 5 and the ones I have fitted are 1" wider
16in Anthracite Bowlers with 265x75R16 BFG KO2's
before and after ![]() Click image to enlarge ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers Last edited by JOW240725 on 14th Jun 2017 10:40am. Edited 1 time in total |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
Eventually bought myself some Blindos
![]() ![]() Click image to enlarge |
