Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK
Page 36 of 42 <123 ... 353637 ... 404142>
Seapod
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Hi All - I'm looking for thoughts/advice for anyone running 265/65/18 on an otherwise standard set up 90 XS SW. Currently it has the bog standard and woefully inadequate 235/85/16 Continental Cross Contact mud polishers.
I'm pretty sure its no coincidence that every picture with this set up seems to be of a shiny, clean land rover. What is the splatter factor like from normal use on rural roads? Has anyone taken the decision to extend wheel arch/mud flaps?
I am by no means OCD about a clean land rover but I use mine a lot and need to be able to see out of the side windows.
Sharing your experience would be appreciated.
Post #610883 20th Mar 2017 4:33pm
JOW240725
Seapod, the 265x65R18 have the same rolling diameter so no problem running them. The wheel offset will effect the amount of splatter up the sides. I'm running spacers for a better turning circle giving it a wider stance but have also fitted Glynn Lewis mudflap extensions which do an excellent job of keeping the sides clean. A lot of other people use Dirt-D-Fenders, which help with the splatter. I have a set for the rear but m yet to fit them. Thumbs Up James
Instagram @suffolk_rovers
Post #610888 20th Mar 2017 4:53pm
Seapod
Thanks James - I have been checking out your Defender after you posted above. Very nice indeed - you have already done many of the things I plan to do.
Are you still running the original wheels ie 235/85/16 ? I see you have spacers added, hence the extended mud flaps, but wasn't quite clear on the tyres themselves.
Post #610910 20th Mar 2017 6:19pm
JOW240725
Thank you Seapod, yes running standard 235x85r16 on boosts et33 with 30mm spacers. Hope to change wheels soon but think I'll stick with 16" but probably 265x75r16... James
Post #610931 20th Mar 2017 7:29pm
pesto_trader
Norway 2005 Defender 90 Td5 SW Tonga Green
18" Anthracite Sawtooths on 265/65 Bfgs:)
Post #611035 20th Mar 2017 10:55pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Post #611111 21st Mar 2017 1:04pm
JOW240725
Yannis - looks great and I believe they're Startech wheels, but would be useful for everyone to add what wheels and tyres they are and what sizes Thumbs Up James
Post #611115 21st Mar 2017 1:21pm
Yannis
Correct they are from JE engineering. Tyres are Atturo R800 285/60R18.
Here is a comparison to the factory setup. The on road grip is unreal, they also reduce roll in the corners a lot due to a smaller side wall. No difference in conform over bumps etc. Terrible in snow. Yet to test on mud.
Post #611119 21st Mar 2017 1:52pm
JOW240725
Thumbs Up Thumbs Up James
Post #611122 21st Mar 2017 2:03pm
L110CDL
Very very nice rims Yannis Bow down Clayton.
Keeper.
Post #611237 21st Mar 2017 10:19pm
hank
Mach 5 16x9 with 285/75/16 BFG MT KM2
Before and after
and a few other photos
Post #614831 6th Apr 2017 8:38am
AJC
Hank, are you sure they're 16x9?
Post #614997 6th Apr 2017 9:20pm
hank
fairly sure, why do you ask? I have a spare 8" Mach 5 and the ones I have fitted are 1" wider
Post #615069 7th Apr 2017 7:33am
JOW240725
16in Anthracite Bowlers with 265x75R16 BFG KO2's
before and after
 James
Post #628791 3rd Jun 2017 11:04pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
Eventually bought myself some Blindos Very Happy
Post #629196 5th Jun 2017 6:21pm
