Home > Technical > wheel hub dented
olistr
Germany
wheel hub dented
Hi,
I just noticed that the wheel hubs have some dents, must have been done by the previous owner/garage when removing the brakedisks. You guys think that filing them flat is sufficient or should I replace them?
Post #1009226 28th Sep 2023 10:24am
geobloke
They are not too bad, filing them flat would be a good plan. Sympathetically of course, don't take too much material off.
Post #1009227 28th Sep 2023 10:31am
TexasRover
Looks like some abuse to me. I don't believe they are all that expensive, but sometimes when things get cheap the quality suffers and refurbishing original stuff is the better option.
Maybe someone here can report if there are any quality issues with this part. Being just steel I would think it be pretty low risk
Post #1009228 28th Sep 2023 10:32am
geobloke
If you wanted to do the job "properly" then you could take it to a metal machine shop and get them to turn the hub down on a lathe. Guarteeed to be a better finish than when using a file.
Post #1009230 28th Sep 2023 10:37am
Dinnu
As long as the face where the wheel rim sits against is flat, then there no need to worry. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1009233 28th Sep 2023 10:44am
It is very hard to understand why someone would do that, but there is a large number of incredibly stupid and inept people out there!
As has been said, as long as the mating surface for the wheel is flat you will have no problem. The damaged areas are so small that filing them flat will be entirely satisfactory (and will also provide a good opportunity for you to demonstrate how to use a file correctly, another largely forgotten skill).
It would be fairly daft to replace the hub for damage that minimal.
Post #1009257 28th Sep 2023 12:52pm
Looks to me like its fallen off of a jack (and maybe been moved at the same time?)
Post #1009294 28th Sep 2023 6:58pm
Something would have had to happen to prevent it landing on the disk in that case, bit it's certainly plausible.
Post #1009297 28th Sep 2023 7:05pm
Retroanaconda
Just normal damage from hammering to get the disc and hub separated.
Post #1009307 28th Sep 2023 7:48pm
But such damage is not "normal" because only a klutz would do that!
Post #1009311 28th Sep 2023 8:24pm
Screbble
It is entirely possible that klutz’s are increasing in population - based on reading the news.
Post #1009332 28th Sep 2023 10:15pm
Sadly we're way past second generation stupid now.
Post #1009337 28th Sep 2023 10:37pm
