Home > Technical > wheel hub dented |
They are not too bad, filing them flat would be a good plan. Sympathetically of course, don't take too much material off.
28th Sep 2023 9:31am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1124 |
Looks like some abuse to me. I don't believe they are all that expensive, but sometimes when things get cheap the quality suffers and refurbishing original stuff is the better option.
Maybe someone here can report if there are any quality issues with this part. Being just steel I would think it be pretty low risk |
28th Sep 2023 9:32am |
If you wanted to do the job "properly" then you could take it to a metal machine shop and get them to turn the hub down on a lathe. Guarteeed to be a better finish than when using a file. |
28th Sep 2023 9:37am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3473 |
As long as the face where the wheel rim sits against is flat, then there no need to worry. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
28th Sep 2023 9:44am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17566 |
It is very hard to understand why someone would do that, but there is a large number of incredibly stupid and inept people out there!
As has been said, as long as the mating surface for the wheel is flat you will have no problem. The damaged areas are so small that filing them flat will be entirely satisfactory (and will also provide a good opportunity for you to demonstrate how to use a file correctly, another largely forgotten skill). It would be fairly daft to replace the hub for damage that minimal. |
28th Sep 2023 11:52am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 |
Looks to me like its fallen off of a jack (and maybe been moved at the same time?)
28th Sep 2023 5:58pm |
Something would have had to happen to prevent it landing on the disk in that case, bit it's certainly plausible.
28th Sep 2023 6:05pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 |
Just normal damage from hammering to get the disc and hub separated.
28th Sep 2023 6:48pm |
But such damage is not "normal" because only a klutz would do that!
28th Sep 2023 7:24pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
It is entirely possible that klutz’s are increasing in population - based on reading the news.
28th Sep 2023 9:15pm |
Sadly we're way past second generation stupid now.
28th Sep 2023 9:37pm |
