![]() | Home > Puma (Tdci) > EGR Blanking |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 ![]() ![]() ![]() |
It isn't necessary, however blanking both ends of the EGR cooler can protect the engine in the event that the cooler develops a leak.
Swim_Cap Member Since: 13 Oct 2019 Location: Cumbria Posts: 17 ![]() ![]() ![]() |
Thanks blackwolf - much appreciated.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2116 ![]() ![]() |
If you have blanked off it’s input and output is there any reason you would not join the cooler input and output coolant hoses together to completely bypass the cooler ?
Yes. Firstly it is hard to access on the TDCi, and secondly it makes it extremely obvious that you have illegally tampered with your emissions equipment, which is not helpful at MoT test time nor if you get tugged for a VOSA/Police inspection.
Leave it in place and blanked and it is unlikely that it will be noticed. |
