Home > Puma (Tdci) > EGR Blanking
Swim_Cap
United Kingdom 2009 Defender 90 Puma 2.4 HT Zermatt Silver
EGR Blanking
Morning all,
Why is it recommended/ important to blank the EGR off when applying the EGR Patch?
The LR in question is a 2.4Tdci.
Thank you.
Post #1007782 16th Sep 2023 8:12am
It isn't necessary, however blanking both ends of the EGR cooler can protect the engine in the event that the cooler develops a leak.
Post #1007785 16th Sep 2023 8:46am
Swim_Cap
Thanks blackwolf - much appreciated.
Post #1007830 16th Sep 2023 2:53pm
Ianh
If you have blanked off it’s input and output is there any reason you would not join the cooler input and output coolant hoses together to completely bypass the cooler ?
Post #1007853 16th Sep 2023 4:39pm
Yes. Firstly it is hard to access on the TDCi, and secondly it makes it extremely obvious that you have illegally tampered with your emissions equipment, which is not helpful at MoT test time nor if you get tugged for a VOSA/Police inspection.
Leave it in place and blanked and it is unlikely that it will be noticed.
Post #1007856 16th Sep 2023 4:45pm
