![]() | Home > Td5 > Random plug |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 206 ![]() ![]() ![]() |
Hello All,
This may be better in the 'leccy section but... I've just removed my Cubby box and found an aftermarket rocker switch hanging around under there. I traced it back to an OE plug that exits the main loom above the Transfer box. From the loom it's 2 cores - 1 black and 1 that could be either white with a black stripe or black with a white stripe. ![]() Click image to enlarge ![]() Click image to enlarge I was hoping that it might be an anti theft thing but the engine starts whichever way the switch is. Any ideas..?? Cheers, Dave 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 224 ![]() ![]() ![]() |
White with a black stripe is High/Low wiring. There is meant to be a switch on the transfer box to control this but sounds like someone has bypassed it to a rocker on yours.
Switching it will affect how sensitive the throttle pedal is. 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Ah, that's interesting - thanks for the answer.
I wonder if it's because I have a Disco (1.2) T/box..?? I guess it dampens the throttle response I'm Low box..?? I'm going 'laning' in a couple of weeks so will experiment then..πππ Thanks again for your help. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Possibly the reason, although I think the D2 box should have the switch too, could be wrong though.
Yes, dampens throttle response. You've reminded me that I need to wire mine in, I never connected it up after doing my td5 swap! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6651 ![]() ![]() ![]() |
Itβs a manual override switch for the high/low detection.
A proper D2 box will have the switch. If a D1 box has been fitted, it wonβt have the switch. Either a previous owner liked the low range pedal response, or thereβs no switch on the box so this has been put in as a workaround. ![]() ![]() |
That's good to know Gents - thanks for the replies.. πππ
I imagine that it could also be helpful in snowy conditions... Cheers. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
