Home > Puma (Tdci) > 2015 Defender 110 Headlight Issue
roche1800
Please can someone give me some advise on the problem I have with my headlights.
Been away for 10 days and went out on Tuesday night and the when I flick the small stem to headlights they do not come on. Side lights do, main beam works when the larger stem is pushed forwarded and the main beam flash works when you pull the stem backwards.
I have checked the about 6 fuses and they are all ok.
Any tips please... cheers
Post #1004501 17th Aug 2023 3:37pm
MK
Likely the indicator/dipped switch is gone. If that is the case, fit a relay. Puma 110" SW
Post #1004552 17th Aug 2023 11:10pm
bear100
The stalk contacts are prone to failure, there is a lot of power flowing through contacts especially the head lights. There are looms available to help like Boomslang for eg but may be to late in your case?
Optimill do a revised complete stalk Thumbs Up
i preums you have checked for voltage at the headlight plug? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1004556 18th Aug 2023 6:24am
roche1800
Thanks for the replies, no I haven’t check for power. Is this a case of using a multimeter and putting each prong on each piece of metal in the plug. I guess if it’s zero it’s the short stalk which is lower down than the indicator/main beam stalk.
Have I got the right one to change?
Post #1004559 18th Aug 2023 6:48am
roche1800
Sorry now read reply from MK and it’s the larger stalk which needs replacing?
Post #1004560 18th Aug 2023 6:49am
roche1800
Would the correct replacement part be:
1.https://www.jgs4x4.co.uk/defender-indicator-horn-headlight-dip-switch-td5-1998/
OR
2.https://www.jgs4x4.co.uk/defender-main-master-light-switch-td5-td4-puma/
Post #1004571 18th Aug 2023 7:48am
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
never really had the larger stalk fail in all of my time driving defenders (25years) the problem seems to be the contacts melt out in the little switch on the side of the column. Like others have said, theres a lot if amps running through that switch and it runs hot. the brass contacts heat up and sink into the plastic that surrounds them. take the switch out and have a look. you'll see one of the contacts is probably sunk and surrounds my melted plastic.
Post #1004575 18th Aug 2023 8:26am
roche1800
Update: fitted a replacement (smaller) stalk for side light and head lights. Issue not resolved.
Any body else encountered the same problem....
Post #1005418 25th Aug 2023 3:15pm
roche1800
In the fuse box is there a relay for the headlights. Side lights work, head lights don't but I can flash the main beam.
Post #1005421 25th Aug 2023 3:42pm
roche1800
Could it be the RH relay in the row of 3?
Post #1005422 25th Aug 2023 4:02pm
Martin
Site Admin
Working through logically.
The off/side/head switch (short switch) is working OK, as when you push the long stalk away, you get main beam. So the output from the short switch in the headlight position, and the input into the long stalk for headlight supply is OK. So the output from the short switch is reaching the input of the long switch (via the headlamp supply relay and the ignition cut off relay).
You have output from the long stalk in main beam position, but not in dip position.
This suggests, as MK said in the first reply, that the long stalk switch has failed.
Or BOTH fuse 15 and fuse 16 under the steering wheel (right and left dipped beam fuses respectively) have failed [unlikely], or a loom wire broken or cut [very very unlikely].
You can test this by removing the 8 pin connector plug from the stalk and switch on the short stalk to headlights.
Then on the long stalk loom plug carefully bridge from the blue (headlamp supply input wire) pin 1 to blue/red (dip output wire) pin 6. Use a piece of wire or paperclip. You should get dipped headlights on - if you do the long switch has failed.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1005428 25th Aug 2023 4:22pm
roche1800
Thanks for your help, it is the horn indicator and main beam long stalk.
However I ended up the wrong part, mine is grey not the blue in the pics. But the blue allows the headlights to work.
Post #1005493 26th Aug 2023 3:35pm
Martin
Site Admin
I think you can swap the switch across from one to the other with a bit of disassembly.
It’s only the grey/blue cancelling ring which is different. The grey one is compatible with the 2015MY steering sensor.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1005497 26th Aug 2023 4:00pm
roche1800
All done and repaired with a complete replacement unit. Thanks.
Old one will be up for sale because it has a use …
Post #1006004 31st Aug 2023 10:33am
roche1800
Martin, all back together and there is this light remaining on, any ideas as it wasn’t there before ….🤔
Post #1006028 31st Aug 2023 1:44pm
