Home > Puma (Tdci) > 2015 Defender 110 Headlight Issue
Page 2 of 2 <12
Martin
Site Admin
Your steering angle sensor is probably now out of calibration if you didn't place it back exactly in the same place as it came off.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1006029 31st Aug 2023 1:45pm
roche1800
Thanks for the prompt response.
Yes I just clicked it back in! How do you go about re-calibrating the sensor please?
Post #1006031 31st Aug 2023 1:47pm
Martin
Site Admin
I don't think it self learns (some cars you can steer full left to right and back again etc), it's a diagnostic tool job.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1006032 31st Aug 2023 1:51pm
Daysleepers
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Keswick Green
Not sure why it’s staying on now, but that’s the traction control light.
Post #1006050 31st Aug 2023 5:26pm
the_lincs_landies
I read on another forum that you have to drive over 5m oh to reset it. No idea if it’s right or not, but worth a try.
Post #1006059 31st Aug 2023 5:56pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
No that is the DSC (Dynamic Stability Control)
ETC (traction control) on the defender is a different light and to get on my soapbox lessor motor manufacturers use the aforementioned light as a traction control light. As they simply have Gaslit the public into thinking that when directional control is lost that means traction and that means taking throttle control away from you to regain it.
My works transit does the same, spins a wheel (in a straight line) and that stupid light comes on and the ECU backs the throttle off.
Coming back on topic
As martin says it's more than likely that you have disturbed the SAS you will have to get it plugged in to do a relearn.
Essentially it's lost how far left or right input you have steered. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1006070 31st Aug 2023 6:51pm
Page 2 of 2 <12
