Home > Td5 > Red engine immobiliser light?
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
Anyone have any ideas?
Jim
Post #1003358 8th Aug 2023 12:51pm
AMBxx
Try locking and unlocking 2 or 3 times with the engine off. I had similar on my Puma at the weekend (different light though).
Post #1003363 8th Aug 2023 1:33pm
jim4244
AMB - Just tried that. Sadly no joy….
Jim
Post #1003365 8th Aug 2023 1:42pm
Ianh
On a puma the red alarm indicator light stays on when the vehicle is started to tell you your fob battery is low.
Given early Puma’s had a 10AS ( later Puma’s had the ALM CH then DH units ) and they both did this I expect it’s the same for pre Puma’s fitted with a 10AS alarm unit.
So change your fob battery, A CR2023 , get a Panasonic or Varta from a reputable supplier as lots of fakes out there.
Hopefully this will be an easy and cheap fix.
Post #1003367 8th Aug 2023 2:02pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Definitely try a new fob battery, but it is the small circular red light in the speedo that flashes to indicate the battery as being low.
My bet is there is a fault with the 10AS unit or a bad connection. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1003371 8th Aug 2023 2:34pm
jim4244
Thanks guys
Just been out and bought a pack of Duracell 2032’s. Replaced batteries in both fobs and the light is still on….😩
Everything else is working fine - central locking, interior courtesy lights and the engine starts no problem…
Jim
Post #1003374 8th Aug 2023 3:07pm
BaronDefenders
I’m afraid it sounds like a 10AS fault. Charlie
2002 Td5 90 (SOLD)
Post #1003375 8th Aug 2023 3:17pm
