![]() | Home > Td5 > Red engine immobiliser light? |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
Try locking and unlocking 2 or 3 times with the engine off. I had similar on my Puma at the weekend (different light though).
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 920 ![]() ![]() ![]() |
AMB - Just tried that. Sadly no joy….
Jim |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2239 ![]() ![]() |
On a puma the red alarm indicator light stays on when the vehicle is started to tell you your fob battery is low.
Given early Puma’s had a 10AS ( later Puma’s had the ALM CH then DH units ) and they both did this I expect it’s the same for pre Puma’s fitted with a 10AS alarm unit. So change your fob battery, A CR2023 , get a Panasonic or Varta from a reputable supplier as lots of fakes out there. Hopefully this will be an easy and cheap fix. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 916 ![]() ![]() ![]() |
Definitely try a new fob battery, but it is the small circular red light in the speedo that flashes to indicate the battery as being low.
My bet is there is a fault with the 10AS unit or a bad connection. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Thanks guys
Just been out and bought a pack of Duracell 2032’s. Replaced batteries in both fobs and the light is still on….😩 Everything else is working fine - central locking, interior courtesy lights and the engine starts no problem… Jim |
I’m afraid it sounds like a 10AS fault. Charlie
