- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
hornet
Re: 2.4 TDCI Front Pipe catalyst removal | |
Defderico wrote:Hello,
I am looking to remove the catalyst on my 2.4 TDCI
Can I remove it without any electronic configuration? I do not see any wiring from it giving info to the ECU
Many thanks for your advice
Regards
You will notice that your consumption decreases and the car "hangs better on the throttle", the turbo revs up faster because the back pressure is lowered. Worthwhile in any case. Should have done it myself much earlier.
10th Aug 2023 2:20pm |
