Home > Puma (Tdci) > 2.4 TDCI Front Pipe catalyst removal
Defderico
France 2002 Defender 90 Td5 SW Alaska White
Hello,
I am looking to remove the catalyst on my 2.4 TDCI
Can I remove it without any electronic configuration? I do not see any wiring from it giving info to the ECU
Many thanks for your advice
Regards
Post #1002641 2nd Aug 2023 5:50am
Yes, on the 2.4 the cat is entirely self-contained. You can replace the pipe with a cat-less one or even drill out and break up the cat matrix inside the original can since it is so close to the manifold flange.
Be aware that it's a legal requirement in most territories though and the may be difficulties if you do.
Post #1002642 2nd Aug 2023 6:31am
hornet
Re: 2.4 TDCI Front Pipe catalyst removal
Defderico wrote:
Hello,
Regards
You will notice that your consumption decreases and the car "hangs better on the throttle", the turbo revs up faster because the back pressure is lowered. Worthwhile in any case. Should have done it myself much earlier.
Post #1003624 10th Aug 2023 2:20pm
