![]() | Home > Technical > Steering box thread size |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6139 ![]() ![]() ![]() |
Googling shows the nut is part # NH614041 and I get this info:
Nut, Hex - UNF - Thread Dia in 1/16" (14/16th = 7/8") - length in 1/8" (4/8ths = 1/4") |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 337 ![]() ![]() ![]() |
Great thanks for that. After a lot of measuring, and trying to understand non-metric (I'm a metric person) it does appear to be UNF 7/8 x 14 thread. So I've ordered a tap and die. Will report back when they arrive.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17614 ![]() ![]() ![]() |
Seldom if ever have I seen such a jumble of confused and meaningless non-data! ![]() This is why the Internet needs to be treated with care! Not a dig at Diesel Jim, by the way, but a dig at wherever this rot came from. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
Jim's decoded the nut's part number according to the British Leyland code:
http://vitessesteve.blogspot.com/2015/10/h...s-etc.html ![]() ![]() |
Interesting link, thank you, I was unaware of this.
If the PN is NH614041, using the link the p/n decodes as follows: N = Nut H = Hex 6 = thread = UNF 14= diameter in units of 1/16" = 14/16" = 7/8" 0 = Steel 4 = medium tensile (precision) 1 = undefined, possibly revision number. So it is 7/8" UNF steel full nut, probably SAE-5(8.8 ), in which case it would take a 1.5/16" AF spanner. If it was a 7/8" UNF 'heavy' steel full nut, the spanner size would be 1.7/16"AF. |
The socket I used to take the nut off was indeed a 1.5/16″AF. I got it here, when I bought my Sumo bar upgrade.
![]() https://gwynlewis4x4.co.uk/product/defender-drop-arm-socket/ |
My Tap and Die arrived today, and I can confirm that it is the right size. So nicely cleaned up the nut, having tried to fit it and it didn't fit, and cleaned the spindle thread.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
All very interesting information and definitely invaluable for the future 👍
