Home > Technical > Steering box thread size
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Does any know what the thread size is on the drop arm of a 4 bolt steering box? After removing the drop arm, the threads are slightly damaged, so want to run a die over it to clean up the threads. It appears to be 1.75 pitch and measures a fraction over 22mm. So is it a M22 with a pitch of 1.75, or is it a non-metric thread?
Thanks
John
Post #1001405 23rd Jul 2023 2:13pm
Googling shows the nut is part # NH614041 and I get this info:
Nut, Hex - UNF - Thread Dia in 1/16" (14/16th = 7/8") - length in 1/8" (4/8ths = 1/4")
Post #1001432 23rd Jul 2023 6:08pm
John P
Great thanks for that. After a lot of measuring, and trying to understand non-metric (I'm a metric person) it does appear to be UNF 7/8 x 14 thread. So I've ordered a tap and die. Will report back when they arrive.
Post #1001503 24th Jul 2023 10:39am
diesel_jim wrote:
... Nut, Hex - UNF - Thread Dia in 1/16" (14/16th = 7/8") - length in 1/8" (4/8ths = 1/4")
Seldom if ever have I seen such a jumble of confused and meaningless non-data! Rolling with laughter
This is why the Internet needs to be treated with care!
Not a dig at Diesel Jim, by the way, but a dig at wherever this rot came from.
Post #1001529 24th Jul 2023 2:11pm
Martin
Site Admin
Jim's decoded the nut's part number according to the British Leyland code:
http://vitessesteve.blogspot.com/2015/10/h...s-etc.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1001545 24th Jul 2023 2:59pm
Interesting link, thank you, I was unaware of this.
If the PN is NH614041, using the link the p/n decodes as follows:
N = Nut
H = Hex
6 = thread = UNF
14= diameter in units of 1/16" = 14/16" = 7/8"
0 = Steel
4 = medium tensile (precision)
1 = undefined, possibly revision number.
So it is 7/8" UNF steel full nut, probably SAE-5(8.8 ), in which case it would take a 1.5/16" AF spanner. If it was a 7/8" UNF 'heavy' steel full nut, the spanner size would be 1.7/16"AF.
Post #1001565 24th Jul 2023 4:28pm
John P
The socket I used to take the nut off was indeed a 1.5/16″AF. I got it here, when I bought my Sumo bar upgrade. Thumbs Up
https://gwynlewis4x4.co.uk/product/defender-drop-arm-socket/
Post #1001568 24th Jul 2023 4:43pm
John P
My Tap and Die arrived today, and I can confirm that it is the right size. So nicely cleaned up the nut, having tried to fit it and it didn't fit, and cleaned the spindle thread. Thumbs Up
Post #1001835 26th Jul 2023 1:28pm
Screbble
All very interesting information and definitely invaluable for the future 👍
Post #1002248 30th Jul 2023 9:46am
