![]() | Home > My Defender > "Kermit" My 110 Hardtop |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 586 ![]() ![]() ![]() |
I've never seen door striker reinforcement before. Why are these needed?
Mitchnotrich Member Since: 27 Apr 2019 Location: Worcestershire Posts: 43 ![]() ![]() ![]() |
Nice! And like Steveww I'm curious about the door striker plates? Do they stop you from ripping jeans/expensive barbour coat back pockets etc as you exit and enter? (how many times have I done that....) 90 - Gone but not forgotten
200 tdi - sold for a song 3 Discoveries - 1/2/3 - cost me a fortune but loved 'em all 2.4 Puma 90 - Current obsession |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 ![]() ![]() |
The B pillars are prone to splitting/cracking (you can just about see a hairline crack in the picture) from the repeated impact of the latch hitting the striker. These spread the load to a larger surface area and help prevent it happening (or in my case, getting worse) They're £25 each, but worth it, in my opinion, if it prevents a common issue. |
Thanks, that makes sense. Where did you get them from? 90 - Gone but not forgotten
Just off of ebay, simple search for "Defender Striker" and these came up.
https://www.ebay.co.uk/itm/295303390553 Only caveat is that they arent as thick as the OEM Plastic plinth, so you'll need shims. |
Thanks, will take a look. 90 - Gone but not forgotten
Mini Update.
After many weeks of resistance, I have finally managed to replace the cross member bolts. You will know all about these from my post in the Puma forum. Before: ![]() Click image to enlarge After: ![]() Click image to enlarge ![]() Click image to enlarge Its a small change , but thought I would add in here for completeness. I have also since my last post removed the "extended" tow bar, and will eventually replace with either the standard tow bar or a NAS Step. I've also started making provisional enquiries around the supply and fit of a galvanised chassis. Last edited by the_lincs_landies on 26th Jun 2023 10:00am. Edited 1 time in total |
Nice bit of kit that. I have always hated the OEM plinth. How are these for adjustment? or are they fixed in one position?! The photos on the listing are terrible for clarity. |
They are fixed in one place, due to the highest and lowest fixing point needing you to drill holes. I got around this by drilling a hole slightly larger that is needed (I think the bolts are M6 and I drilled M8 ) and then that at least allows a degree of adjustment - just not as much as the shims/OEM "slots" in the B Pillar. I'd also advise getting shims if you get these as they seem thinner (only marginally) than the OEM striker plate plinth. |
Many thanks
Last night, with nothing on TV and nothing better to do I made a start on tidying up the sealant on the wheel arches. When it was applied it was just wiped on for ease and to ensure it adhered.
Now with the help of a number plate removal “scraper” for sticky pad number plates and a bottle of Acetone, we are on the journey to just the holes being filled. See above for before… After: ![]() Click image to enlarge |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
I like what you’re doing with your 110! Keep it up.
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Thanks @BaronDefenders. UPDATE: As an extension to my post of 24th, I last night spent a further 4.5 hours with a litre of Acetone in the back of my 110, finishing up what I started, this also included the contact adhesive from the old carpet this time too. Below is the before and after. I've also (although I have no pic) replaced the rubber washers with Nylon thanks to @LandRoverAnorak's suggestion. BEFORE ![]() AFTER ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10955 ![]() ![]() |
Great work your doing there, very satisfying
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
