![]() | Home > Expedition & Overland > Drivelodge or Dormobile Pop-top for overlanding? |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 256 ![]() ![]() ![]() |
With the fold down bed in the Drivelodge can you store bedding on it when the roof is down and or when the bed is up? |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
I can leave a double mattress and sleeping bag in when its all fastened up / stowed. Not much more than that though. Its about the same as I could leave in my hard shell roof tent
![]() Is the roof itself fairly stiff, could it take some cargo rails for example so a light box or solar panel could be fitted? |
Not sure about cargo rails but will defo take solar panels as that is one of the options I was looking at.
To be fair one of the reasons I went with this set up was to keep weight off the roof and also lower the overall weight and centre of gravity. Having done lots of expedition work, I don’t like having weight up high. ![]() |
Slept in mine for a week now
![]() Was a bit fresh last night... ![]() Click image to enlarge ![]() |
spider Member Since: 06 Jun 2017 Location: Suffolk Posts: 8 ![]() ![]() |
"White Landy" very nice looking set up you have there. What make it the roll cage? as would like to fit one to ours. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
I love the drivelodge of yours Camel. But I always have a roof rack which doesn’t seem viable.
Yep, if you regularly carry stuff up top that could be an issue. Saying that, I dont' like carrying stuff on the roof for lots of reasons (increased height, centre of gravity, the faff of getting it up there etc etc).
If I have to carry more gear than I can fit inside, I tend to hook the penman up instead. ![]() |
white Landy Member Since: 03 Mar 2015 Location: Mayen Posts: 19 ![]() ![]() ![]() |
Hi mate, It‘s from safety devices. Fits perfect. |
Thanks for the reply.
Is there any internal bar work to it? As "Safety Device" have said they do not do one to fit. Or do you know the part number or pics of inside? Cheers |
I fitter an internal bar as well. It‘s not part of the external cage. It‘s from the cage from an 110. See pics below.
![]() Click image to enlarge ![]() Click image to enlarge |
So, are the two parts joined together?
Are they meant to go together or have you have to get other brackets made to join them? |
tommobot Member Since: 15 May 2018 Location: Stratford Upon Avon Posts: 32 ![]() ![]() |
This isn't mine, its a german fellas from one of the facebook groups...
But he used a drivelodge roof, and amended an existing rollcage.. I'm looking to do similar, the only 'iffy' element is the odd kink over the rear door.. (purely from looks perspective) TBH, I think he's absoutely nailed it! I think theres a video walk round on YT somewhere aswell that I have seen.. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Yes, this are two different „cages“. However they fit together By using the original brackets. |
