Home > Expedition & Overland > Drivelodge or Dormobile Pop-top for overlanding?
Page 2 of 3 <123>
J12Engineering
Bowbearer wrote:
Looking at the Drive lodge it seems a bit narrower than other Roof Opening tents.
On my 110 I have a Safety Devises Cage, external front, internal rear as per Camel 100s.
Dismissed the opening roof as I thought it wouldn't fit.
Do you think it is narrow enough to accommodate the cage? What width length is it?
Would solve many problems.
Thanks,
That is the configuration I intend to use in a 110 Overland I have in build at present.
There are many variants of SD roll cage. Are your external bars as low as this SD front external cage? If so yes the roof will fit externally.
You may have to clamber around your internal cage though, and dependent upon how tight to the roof internally the rear cage is, potential exists for the internal pop top frame to be impinged by the cage. That said, its all straight forward to adapt between the 2 structures to achieve both occupant protection by the cage, and rigidity in the roof to support the pop top.
Post #981760 8th Feb 2023 1:48pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
camelman wrote:
I've had the drop down bed fitted in the drivelodge. It's on seperate gas struts and the whole bed folds up.into the roof when not in use
When folded down, it gives the full length of the roof as bed space
We can sleep 4+ dog, 2 up and 2 down
With the fold down bed in the Drivelodge can you store bedding on it when the roof is down and or when the bed is up?
Post #982364 13th Feb 2023 9:32pm
camelman
I can leave a double mattress and sleeping bag in when its all fastened up / stowed. Not much more than that though. Its about the same as I could leave in my hard shell roof tent
Post #982375 13th Feb 2023 10:16pm
8619simon
Thumbs Up Thanks
Is the roof itself fairly stiff, could it take some cargo rails for example so a light box or solar panel could be fitted?
Post #982387 14th Feb 2023 7:17am
camelman
Not sure about cargo rails but will defo take solar panels as that is one of the options I was looking at.
To be fair one of the reasons I went with this set up was to keep weight off the roof and also lower the overall weight and centre of gravity.
Having done lots of expedition work, I don’t like having weight up high.
Post #982388 14th Feb 2023 7:32am
camelman
Slept in mine for a week now Laughing
Was a bit fresh last night...
Post #982389 14th Feb 2023 7:39am
spider
white Landy wrote:
Run the Drivelodge since last June. So far so good. Price is maybe the best on market. No experience with the Doormobile, actually never saw one. For our needs (2person) perfect. fits perfect to the shape of the roof. If you fit a checkerplate you can still put some luggage on top.
"White Landy" very nice looking set up you have there. What make it the roll cage? as would like to fit one to ours.
Post #1057261 13th Jan 2025 3:22pm
keith
I love the drivelodge of yours Camel. But I always have a roof rack which doesn’t seem viable.
Post #1057350 14th Jan 2025 1:28pm
camelman
Yep, if you regularly carry stuff up top that could be an issue. Saying that, I dont' like carrying stuff on the roof for lots of reasons (increased height, centre of gravity, the faff of getting it up there etc etc).
If I have to carry more gear than I can fit inside, I tend to hook the penman up instead.
Post #1057352 14th Jan 2025 1:46pm
white Landy
Germany 2015 Defender 110 Puma 2.2 SW Fuji White
Hi mate,
It‘s from safety devices. Fits perfect.
Post #1057457 15th Jan 2025 3:57pm
spider
Thanks for the reply.
Is there any internal bar work to it? As "Safety Device" have said they do not do one to fit. Or do you know the part number or pics of inside? Cheers
Post #1057465 15th Jan 2025 5:02pm
white Landy
I fitter an internal bar as well. It‘s not part of the external cage. It‘s from the cage from an 110. See pics below.
Post #1057485 15th Jan 2025 6:47pm
spider
So, are the two parts joined together?
Are they meant to go together or have you have to get other brackets made to join them?
Post #1057525 16th Jan 2025 11:07am
tommobot
This isn't mine, its a german fellas from one of the facebook groups...
But he used a drivelodge roof, and amended an existing rollcage..
I'm looking to do similar, the only 'iffy' element is the odd kink over the rear door.. (purely from looks perspective)
TBH, I think he's absoutely nailed it! I think theres a video walk round on YT somewhere aswell that I have seen..
Post #1057535 16th Jan 2025 12:50pm
white Landy
Yes, this are two different „cages“. However they fit together By using the original brackets.
Post #1057539 16th Jan 2025 1:15pm
Page 2 of 3 <123>
