Home > Tdi > dim-dip
dim-dip
how do I remove the dim-dip on my 1995, 300 tdi ?
I've been told about the yellow relays - wrong, the pink relay - wrong .. can't be that difficult any ideas?
Post #94154 14th Oct 2011 7:59am
Grockle
Disconnect the ressistor which is on the fire wall. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #94158 14th Oct 2011 8:19am
ibexman
Behind the spedo clocks on the right go to yor lr dealer ask for row spec relay Thumbs Up
Post #94160 14th Oct 2011 8:44am
Not sure about the 300TDi, but on my Puma I simply unplugged the resistor pack (on the Puma it is in the RH wing in front of the aerial - not easy to find), that is all that is needed.
An unexpected advantage to this also came when my dip/main switch contacts melted (another common problem) leaving me with no dip beam - I simply connected the two terminals in the disconneted connector together to give full dip beam on sidelights. A useful get-you-home fix.
Post #94180 14th Oct 2011 9:36am
thanks Grockle, is that behind the dash or under the bonnet side of the firewall ?
I've been told about the pink relay behind the dash, will try that if the resistor approach fails.
Post #94196 14th Oct 2011 11:04am
Grockle
under the bonnet mate 2.4 90 XS
Post #94198 14th Oct 2011 11:44am
cheers Thumbs Up
Post #94199 14th Oct 2011 11:48am
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
Re: dim-dip
have you lost your dip beam then ??
Post #94246 14th Oct 2011 4:52pm
drewster
Post #94248 14th Oct 2011 5:01pm
drewster - i've not lost my dim-dip - i don't like it so i want to remove it.
Post #94258 14th Oct 2011 6:00pm
drewster
is that because it is crap then like all 90 and 110 ??
Post #94261 14th Oct 2011 6:13pm
drewster
i made the mistake of putting in hi rated bulbs 80/100 then found out after it burnt out the switch that the currant was to much for it and the current runs through the switch Censored i had to strip it all down and the best bit was that i was in heraford when this happened so a small bodge ie ignition live to the dip beam on the back of the block to get me home wont do that again lol
Post #94262 14th Oct 2011 6:17pm
hi Grockle
I've had a look on the bulkhead and can't see anything obvious .. can you tell me what I should be looking for ? there is a relay jobbie next to the fuse box on the right but from my knowledge a resistor would probably be a ceramic block with wires wrapped around it ... got a picture mate ?
cheers
bp
Post #94339 15th Oct 2011 11:39am
landy andy
This will show you where it is.
http://forums.lr4x4.com/index.php?showtopic=71364
Andy
Post #94367 15th Oct 2011 3:33pm
cheers Andy ... I'll check in the morning Thumbs Up
Post #94381 15th Oct 2011 6:36pm
