Home > Tdi > dim-dip
Page 2 of 2 <12
Grockle
are you sorted bp ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #94462 16th Oct 2011 7:42am
cheers Grockle / Andy
I found the relay and pulled it, tried the lights, have side lights, switch again and no dip beam Big Cry
Then I had a route around under the bonnet and found the resistor - WTF do they put it there ?
I'm going to leave it as it is for the time being .. when I take a wing off I'll attend to it then.
Flippin stupid system ...
Post #94492 16th Oct 2011 11:47am
landy andy
I thought you just had to pull the relay out and connect two terminals?
This shows the terminals
http://forums.lr4x4.com/index.php?showtopic=71364
Andy
Post #94565 16th Oct 2011 7:55pm
So that the air flow keeps the resistor cool... it's a huge great aluminium clad wire wound, dropping the 13 or so volts down to about 6v to dim the lights, so gets quite warm/hot. not really safe (read: cool enough) to be behind the dash.
Andy
^^^ You're correct. just make up a link to short the 2 main cables together. Then it totally bypasses the system.
Post #94582 16th Oct 2011 8:34pm
Jamie, when we meet on the plains, maybe you could show me Thumbs Up cheers steve
Post #94608 16th Oct 2011 9:25pm
No probs.
I'll get some pics of the bulkhead on the project90, so you can see the relay in question.
I meant to post the party number a while back, as there is a proper "relay" (which is just an empty box with the link inside it) to bypass the dim-dip.
Post #94611 16th Oct 2011 9:30pm
cheers Jamie. so to be clear, I found the pink relay behind the clocks on the dash-dials. The other link/url suggests a wire link between a couple of the terminals (red/blue wires), the relay has about 7 or 8 connectors on it .. I did not try and open it... nor could I see any red/blue wires.
cheers
steve
Post #94613 16th Oct 2011 9:34pm
Yes, that's right.
See picture below, my 90 bulkhead before I put the dash trim in place, you can see the pink "relay" on the RH side, with the blue/red wires going into it.
If you pull said relay out, you should have 7 terminals on the relay base. you need pins 8 & 2, both blue with red trace. This is the main feed in (pin 8, from the off/side/main column switch, via ignition fed relay) then out to the headlights via fuses 22 & 23.
All the other 5 pins of that relay relate to the dim-dip stuff. So, short the 2 pins out, and you'll bypass it all. But use decent sized connectors to slide into the socket, or get the correct "bypass" unit (part number to come later when i go out and get it! probably tomorrow now) or get an old relay that fits, remove the lid and guts and solder in a nice sized piece of cable across the 2 terminals)
Post #94615 16th Oct 2011 9:55pm
cheers Jamie, I'll take a look tonight.
Post #94654 17th Oct 2011 8:04am
took the ICE defender out yesterday to visit the dealership because the 300's headlights stopped working altogether. standard switch costs £50, copy part £9.99
pulled the dash apart and found the pink D/D relay, did some searching on the web and made the jumper lead - i thought it's worth a try, plugged in and hey-presto ... no dim-dip, side lights, headlights and full beam all working Thumbs Up
don't even need the switch...
Post #203562 20th Jan 2013 2:52pm
Page 2 of 2 <12
