![]() | Home > Tdi > dim-dip |
Disconnect the ressistor which is on the fire wall. 2.4 90 XS
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Behind the spedo clocks on the right go to yor lr dealer ask for row spec relay
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17683 ![]() ![]() ![]() |
Not sure about the 300TDi, but on my Puma I simply unplugged the resistor pack (on the Puma it is in the RH wing in front of the aerial - not easy to find), that is all that is needed.
An unexpected advantage to this also came when my dip/main switch contacts melted (another common problem) leaving me with no dip beam - I simply connected the two terminals in the disconneted connector together to give full dip beam on sidelights. A useful get-you-home fix. |
thanks Grockle, is that behind the dash or under the bonnet side of the firewall ? I've been told about the pink relay behind the dash, will try that if the resistor approach fails. |
under the bonnet mate 2.4 90 XS
cheers
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
have you lost your dip beam then ?? |
if so this is who i use
https://www.lrdirect.com/XPB101290-Indicat..._https=yes |
drewster - i've not lost my dim-dip - i don't like it so i want to remove it.
is that because it is crap then like all 90 and 110 ?? |
i made the mistake of putting in hi rated bulbs 80/100 then found out after it burnt out the switch that the currant was to much for it and the current runs through the switch
hi Grockle I've had a look on the bulkhead and can't see anything obvious .. can you tell me what I should be looking for ? there is a relay jobbie next to the fuse box on the right but from my knowledge a resistor would probably be a ceramic block with wires wrapped around it ... got a picture mate ? cheers bp |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5850 ![]() ![]() |
This will show you where it is.
http://forums.lr4x4.com/index.php?showtopic=71364 Andy |
cheers Andy ... I'll check in the morning
