![]() | Home > Maintenance & Modifications > Rear Cross Member Conundrum |
Greg23w Member Since: 14 Jan 2023 Location: Uttoxeter Posts: 5 ![]() ![]() ![]() |
So I have bought an ex farm truck 110 double cab. Like all farm trucks it has seen some action, to put it mildly... So much action in fact that i need to replace the rear tub. The rear cross member also needs replacing.
From what I can work out, they are linked to each other in the replacement process. So when a new tub is fitted it is aligned with the cross member and vice versa. My question is which to do first? Many thanks |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
I would do cross member first so that the original tub gives a datum for the new cross member
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Agree with this - crossmember first!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
By preference I would always remove the tub then jig the crossmember. It would be an approach of last resort to replace the crossmember with the tub in situ (appropriate perhaps on a 110 SW or DC where removing the tub is extremely non-trivial).
Many thanks for the replies chaps. I will go with the general consensus and do the crossmember first.
That is unless anyone has any links to information about creating jigs for it. I would prefer to have the tub off to weld the top of the chassis rail too... |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 795 ![]() ![]() ![]() |
Hello,
I'd probably leave the tub on, tack the crossmember up with the old tub in place then when you pull the tub off fully- complete the welds whilst you have better access, then fully reassemble. Regards Chris |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6138 ![]() ![]() ![]() |
Here's my last 90 I built.... just made a simple frame welded onto the chassis and bolted to the crossmember body tags (I bolted the box to the tags first, then welded the horizontal bits onto the chassis wherever was touching, just a couple of small welds needed)
Once all was changed just grind off the weld, dab of paint, no one's any the wiser. ![]() Click image to enlarge |
