Home > Maintenance & Modifications > Rear Cross Member Conundrum
Greg23w
United Kingdom 2003 Defender 110 Td5 DCPU Cairns Blue
So I have bought an ex farm truck 110 double cab. Like all farm trucks it has seen some action, to put it mildly... So much action in fact that i need to replace the rear tub. The rear cross member also needs replacing.
From what I can work out, they are linked to each other in the replacement process. So when a new tub is fitted it is aligned with the cross member and vice versa.
My question is which to do first?
Many thanks
Post #978040 14th Jan 2023 5:50pm
dailysleaze
I would do cross member first so that the original tub gives a datum for the new cross member
Post #978079 14th Jan 2023 8:07pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Agree with this - crossmember first!
Post #978095 14th Jan 2023 9:04pm
Dinnu
I did replace a crossmember once with the tub off. I made some simple jigs on the old cross member before cutting it off, so the new crossmember went in in exactly same position as the original.
Note that I replace the basic end of the crossmember without chassis leg extensions, so to cut the old one off really needed the tub off. With or without extensions really depend on the condition of the chassis legs though but makes a cosmetically nicer repair without the extensions, IMHO. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #978173 15th Jan 2023 12:30pm
By preference I would always remove the tub then jig the crossmember. It would be an approach of last resort to replace the crossmember with the tub in situ (appropriate perhaps on a 110 SW or DC where removing the tub is extremely non-trivial).
Post #978176 15th Jan 2023 12:53pm
Greg23w
Many thanks for the replies chaps. I will go with the general consensus and do the crossmember first.
That is unless anyone has any links to information about creating jigs for it. I would prefer to have the tub off to weld the top of the chassis rail too...
Post #978276 16th Jan 2023 8:52am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Crossmemember
Hello,
I'd probably leave the tub on, tack the crossmember up with the old tub in place then when you pull the tub off fully- complete the welds whilst you have better access, then fully reassemble.
Regards
Chris
Post #978283 16th Jan 2023 9:17am
Here's my last 90 I built.... just made a simple frame welded onto the chassis and bolted to the crossmember body tags (I bolted the box to the tags first, then welded the horizontal bits onto the chassis wherever was touching, just a couple of small welds needed)
Once all was changed just grind off the weld, dab of paint, no one's any the wiser.
Post #978373 16th Jan 2023 5:01pm
