Home > Td5 > New rear door prep
Page 3 of 4 <1234>
excossack
Tool arrived with a selection of rivnuts.
What size hole do you drill to accept the rivnut? Same size as the main body of the rivnut ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #968891 25th Oct 2022 4:47pm
Essentially, yes. The rivnut should be a snug fit in the hole so the nearest drill bit size. Darren
Post #968914 25th Oct 2022 8:22pm
excossack
Cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #968934 26th Oct 2022 7:14am
excossack
No real door updates other than I picked up a sheet of 3mm ally to use as the new door card
Hopefully Sunday will be dry and I can get some more work done. 1999 Defender TD5 110
Regards
John M0VAZ
Post #970795 11th Nov 2022 5:53pm
geobloke
Oooo are you going to add anything like a cooker shelf or storage?
Post #970797 11th Nov 2022 5:56pm
excossack
It wasn't my original plan. But I had considered some kind of door shelf thingy. 1999 Defender TD5 110
Regards
John M0VAZ
Post #970820 11th Nov 2022 7:43pm
excossack
Managed to get a bit more done today.
Got the 3mm ally sheet cut to go on the door.
Drilled the holes through the 3mm ally that will be used to attach it to the door frame.
Got all the holes drilled in the door frame.
1 rivnut done and fixed.
Then spent the next hour faffing to try and get the rest of them done.
Managed to damage the thread on the rivnut gun that takes the rivnut insertion tool.
Test fitted the new door lock but can't get the barrel housing centred in the door Sad
Saw me arse and packed in.
I think I will be replacing the rivnut tool for a new one. Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #971008 13th Nov 2022 6:34pm
excossack
Managed a bit more on the door.
The original old vinyl covering was removed from the hardboard and test fitted to the sheet of ally and all in all, fits OK.
I think I have some contact adhesive to mount the vinyl/foam covering to the ally sheet. This will be mounted to the door frame via bolts/rivnuts.
At the weekend found some time to test fit the door to the car just in case and gave me a chance to compare side by side. I need to drill a 13mm hole for high level brake light wiring and also a mount for an earth cable.
Vinyl to ally sheet testing
Test fit to the Landy
Old and new carrier
Old
New
I did discover the old door hinges have play - which I am going renew.
Next stop is drill holes and get the door over to paint man. 1999 Defender TD5 110
Regards
John M0VAZ
Post #976665 4th Jan 2023 1:02pm
Screbble
Looking good John.
A job well done 👍
Can’t wait to see it painted.
Post #976831 5th Jan 2023 8:04pm
excossack
Cheers. Its coming along slowly. Working in a cramped shed or when raining slows me down a bit. 1999 Defender TD5 110
Regards
John M0VAZ
Post #976885 6th Jan 2023 10:43am
Screbble
Yes I can just about fit my 90 in the garage - loaded with ballast to lower it by 5-10mm to clear the up and over door mechanism. Makes such a difference this time of year when doing ‘bigger’ jobs.
Mind you, all the ‘stuff’ I had to move out of the garage is now tripping me up.
Have you considered one of those gazebo type car shelters?
Post #977001 7th Jan 2023 3:05pm
excossack
A gazebo type shelter is an option but lack of storage space to keep it.
Maybe more room once I upgrade the shed to a 10x10ft rather than a 8x10ft. 1999 Defender TD5 110
Regards
John M0VAZ
Post #977019 7th Jan 2023 5:45pm
excossack
Popped into see the paint man to discuss painting the door. After a chat, I think the job has grown to whole rear end respray...
Some ally corrosion on the panel where the number plate attaches to and the same the other side.
Might as well get the job done properly and get these replaced as well. But this does delay things...
mmmm 1999 Defender TD5 110
Regards
John M0VAZ
Post #977368 10th Jan 2023 1:46pm
geobloke
Plus they do have the habit of blowing away Rolling Eyes Rolling with laughter
Post #977406 10th Jan 2023 4:53pm
Screbble
mmmm
These things always happen to me
I’m sure that cost aside, it’ll be well worth it 👍
Post #977413 10th Jan 2023 5:22pm
Page 3 of 4 <1234>
