Home > Td5 > New rear door prep
Page 2 of 4 <1234>
geobloke
excossack wrote:
donmacn wrote:
I can say that the Nakatanenga upper gas strut is a nice piece of kit. I'm happy with it after maybe 2 years.
On the other question about drilling holes/using screws to hold things in place, can I put in a vote for using rivnuts. This is what I did when I built up my rear door - and once you start using them, you see other uses all over the place. If you're drilling a hole in a galvanised door for a screw, you might as well drill a slightly bigger one for a rivnut. You can get stainless ones, and I've used M4 or M5 in the doors.
I think I've used a company called rivetwise a few times, and a hand-grip setting tool isn't too expensive.
I hadn't considered Rivnuts (off to google to see how they work)
Excellent solution to captive nuts. I have the Rivet tool if you need one Thumbs Up
Post #968422 20th Oct 2022 11:06am
excossack
No probs. Shelter is always handy.
I think I will looking at new 2nd row doors as well...But that can wait until next year 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #968423 20th Oct 2022 11:07am
excossack
Cheers GB. 1999 Defender TD5 110
Regards
John M0VAZ
Post #968424 20th Oct 2022 11:07am
geobloke
No kidding, shelter is essential here in southern Denbighshire... Rolling Eyes
Post #968428 20th Oct 2022 11:23am
excossack wrote:
There is a reinforcing plate at the rear
I was thinking of an additional plate across the back as well
Ah, that's something at least but I don't think you'd regret beefing it up.
When you come to assemble it after painting, I find that a rubber gasket between the carrier and the door to be a good idea to preserve the finish.
I like Don's idea of reinforcing the whole door with chequer plate, but I guess you could always use plain ali sheet, 2-3mm, and cover it with vinyl if you wanted a slightly less agricultural look to it.
Others have mentioned rivnuts, which are a great way to fix this sort of stuff, and stainless ones would be ideal for this application. I can also recommend one of these inexpensive tools to set them with:
Hope that helps. Darren
Post #968433 20th Oct 2022 12:04pm
excossack
Cheers Darren. A gasket is a good idea, I have some thing neoprene rubber left over from when I did the chequer plate work a while ago. That does look quite the tool Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #968436 20th Oct 2022 12:44pm
excossack
Or a tool like
https://www.ebay.co.uk/itm/383145567965?ep...R5S_yOf-YA
? 1999 Defender TD5 110
Regards
John M0VAZ
Post #968464 20th Oct 2022 5:41pm
geobloke
Thats pretty much what I have John. Works a treat and an incredibly useful tool to have in your garage Thumbs Up
You just need stronger hands to use it than the one LRA posted up. Rolling Eyes
Post #968465 20th Oct 2022 5:46pm
excossack
Its all down to leverage! 1999 Defender TD5 110
Regards
John M0VAZ
Post #968467 20th Oct 2022 5:50pm
geobloke
There's a life lesson in that somewhere Wink
Post #968469 20th Oct 2022 5:51pm
excossack
Indeed there is.
Tonight I got the wiper motor hole drilled and ordered new rubber seal and new washer for the external part of the wiper motor.
Next is a test fit and then the door card issue to resolve.
Hopefully then into paint along with new door hinges
Once back from paint its getting cavity waxed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #968470 20th Oct 2022 5:54pm
I've got one of those 90 degree tools too, but now only ever use it if I can't get the one pictured into position. They're really chalk and cheese, particularly if setting steel or stainless steel rivnuts. Darren
Post #968487 20th Oct 2022 9:17pm
geobloke
Completely agree LRA I have the same pair (basically) for pop rivets. As you say chalk and cheese.
Post #968531 21st Oct 2022 11:04am
excossack
Tool and inserts arrived today. Just need some dry weather to work outside... 1999 Defender TD5 110
Regards
John M0VAZ
Post #968794 24th Oct 2022 2:00pm
excossack
Also ended up ordering a new door lock, gasket and bolts. The old door lock felt like it was locked but would magically unlock itself Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #968795 24th Oct 2022 2:04pm
Page 2 of 4 <1234>
